Pressure sensor
  • Hi gents,
    Could you please provide me the reference of the Air pressure sensor of 1750 tbi 159.
    I need to change it and the bosch référence on the sensor was erased.
    The sensor is on the pipe prior the throttle body.
    Thanks
    Sent from my RNE-L21 using Tapatalk
  • Believe me, the sensor mentioned above is fitted for your purpose.
    But you sensor with the Digits 437 is normally fitted for Saab, Opel, Vauxhall, Citroen, Ford and Peugot. Doesn't matter! The Opel engine is like the AR 159 1.8 tbi engine one of a whole GM-Family. Therefor and in my opinion is your sensor also fitted for your car!
  • Thanks for your response, but the one that i have the last 3 digits are 437 and the shape is not like this
    Dear walid. You have to double check your mentioned part number, refer the last 3 digits. The part number which was forwarded to you before is the correct one. Maybe the sensor which is fitted in your car, currently ,was replaced by an other "spare part". Please note that tere are many OEM - numbers for similar parts existing. I only wonder about the different shape you mentioned.
